jpbonesaw Posted May 17, 2022 Share Posted May 17, 2022 Good afternoon people, I'm having an issue with the fuel pump on my 2015 TC. power on each side of the fuse. Vehicle starts with starter fluid. Won't restart with the inertia switch reset proceedure. The pump is not turning on. Has any one had a similar issue and if so what did you find. Jp Quote Link to comment Share on other sites More sharing options...
G B L Posted May 18, 2022 Share Posted May 18, 2022 When you turn on the key do you hear the pump cycle? If not pull the relay and jump the relay see if the pump runs. A good Scan tool would be a great help at this point. Quote Link to comment Share on other sites More sharing options...
jpbonesaw Posted May 19, 2022 Author Share Posted May 19, 2022 No the pump didn’t turn on . Funny thing it started later in the day with the hood open and the sun on the engine compartment. I am thinking the maple trees are shedding and filled the drain plugs and it rained which in turn got something wet. Still not trusting it though. I had also used a replacement key which I hear could mess with the ignition. Quote Link to comment Share on other sites More sharing options...
G B L Posted May 25, 2022 Share Posted May 25, 2022 Any more news? Quote Link to comment Share on other sites More sharing options...
