MarcinS87 Posted April 22, 2022 Share Posted April 22, 2022 (edited) I want to get Rims for my TC and have an opportunity to buy 18” rims with 8.0 width and a 55mm offset. Will this Rim work for my TC? Any suggestions? I know I will have to get a 45 tire for the set. Edited April 22, 2022 by MarcinS87 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted April 23, 2022 Share Posted April 23, 2022 Do you want the aftermarket wheels and tires to drive the same? You will need to configure a wheel and tire combination with similar specifications. You need more information. You have to figure out what the full dimensions of the wheel are. You need the backspacing, the pitch circle diameter, bolt pattern, and backspacing. Then you can shop for tire size. If you don't care, then you just install whatever will fit. Your only consideration is that when at full lock steering, nothing is making contact. Quote Link to comment Share on other sites More sharing options...
BobbyP Posted April 27, 2022 Share Posted April 27, 2022 Is carrying a load important? I went with Hancook ventus concept 2 size 235/45R17. that size allowed me to keep the XL rating. not sure if they make that in 18 now. Quote Link to comment Share on other sites More sharing options...
