Engine and trans temp readout-possible to put on dash readout ?
Just a question. I have a 2020 LEB Transit Connect wagon. The read out for speed, compass, etc that is selectable and read out displayed on the dash. Is it possible to add engine temp ( digital ) and trans temp in ( digital) form ? My Jeep has gauges but also the ability to scroll through and read engine temp, trans temp, tire psi, voltage, and some other items. Although my Connect has a temp gauge, I would like the ability to read engine temp, trans temp, and voltage in exact (digital) numbers when ever I want. Is this possible to change or add to my selectable screen read outs .
I don't know if the 2020s are different, but you can't add or change items to the display on the previous models. The cluster programming does not support this. The only changes you can make is adding features like cruise control and DRL using Forscan or IDS. Even these are limited by the model year programming in the cluster.
