Timing belt AND chain!?
SandyHenderson
Hi. My 06 transit connect has 110000 miles on clock. I'm worried about timing belt/chain so Ive been asking around for quotes. Two garages told me that I have a wet and dry belt. First garage said it's around £1k to change them. Second one was £700. I phoned Ford just there to make sure it's definitely a wet and dry belt set up. They told me I have a dry timing belt AND a chain. I asked if that's the one in the cassette type thing. They said yes and said I wouldn't need to change the chain, just the belt and water pump need changed.
Can anyone confirm this is correct as I'm sceptical still and havnt got a clue.
If this is true then why are independent garages quoting me for a wet and dry belt change when ford says its a chain and doesn't need replacing?
Please help?
This is the series engine in your Transit Connect.
Jump to navigation Jump to search
Mazda L engine
Mazda MX-5 (NC) 2.0 MZR LF-VE engine
Overview
Manufacturer
Mazda
Also called
MZR
Duratec
EcoBoost
Production2001–present
Layout
ConfigurationInline 4
Displacement
1.8 L; 109.7 cu in (1,798 cc)
2.0 L; 122.0 cu in (1,999 cc)
2.3 L; 138.0 cu in (2,261 cc)
2.5 L; 151.8 cu in (2,488 cc)
Cylinder bore
83 mm (3.27 in)
87.5 mm (3.44 in)
89 mm (3.50 in)
Piston stroke
83.1 mm (3.27 in)
94 mm (3.70 in)
100 mm (3.94 in)
Block materialAluminum
Head materialAluminum
ValvetrainDOHC 4 valves x cyl. with VVT (some versions)
Compression ratio9.7:1, 10.0:1, 10.8:1, 12.1:1
Combustion
TurbochargerOn some versions since 2010
Fuel system
Sequential multi-port fuel injection
Direct injection
Fuel typeGasoline
Oil systemWet sump
Cooling systemWater-cooled
Output
Power output125–285 hp (93–213 kW; 127–289 PS)
Torque output122–280 lb⋅ft (165–380 N⋅m)
Chronology
PredecessorMazda F engine
SuccessorMazda SKYACTIV-G engine
The Mazda L-series is a mid-sized inline 4-cylinder gasoline engine designed by Mazda as part of their MZR family, ranging in displacement from 1.8L to 2.5L. Introduced in 2001, it is the evolution of the cast-iron block F-engine. The L-series is used by Ford as their 1.8L to 2.5L Duratec world engine.
The L-engine uses a chain-driven DOHC, 16-valve valvetrain with an all-aluminum block construction and cast-iron cylinder liners. Other features include fracture-split forged powder metal connecting rods and a one-piece cast crankshaft.
