maritimesbob Posted September 9, 2020 Share Posted September 9, 2020 Hi all, I have a 2004 tdci connect. I noticed today when the van was on a slope, engine facing down there was some coolant leaking down through by the crank pulley. On level ground there is very little leakage if any. Probably the water pump gasket has perished? Is there anything else this side of the engine that could leak water? It's dry around the head and top end of the block. Attached a couple of pics, thanks. Quote Link to comment Share on other sites More sharing options...
G B L Posted September 11, 2020 Share Posted September 11, 2020 Yes there is a shaft seal at the water pump on that side of the engine. Does it leak when the engine is running?Does it leak when the van sits? Quote Link to comment Share on other sites More sharing options...
maritimesbob Posted September 11, 2020 Author Share Posted September 11, 2020 No, seems to be only when sitting still and only when the engine is on a slope downward. That's why I was thinking the gasket has perished as coolant will be sitting inside the pump and dripping out? Quote Link to comment Share on other sites More sharing options...
G B L Posted September 12, 2020 Share Posted September 12, 2020 If the gasket at the water pump was leaking it would leak a lot.Sounds like a pressure test is needed to see where the Antifreeze is coming from. Quote Link to comment Share on other sites More sharing options...
maritimesbob Posted September 14, 2020 Author Share Posted September 14, 2020 Fitted a new water pump and gasket this morning. It does seem to have been leaking from the pulley shaft area. Anyways, fitted up and taken for a drive. Nice and dry under there. Hopefully sorted now, oh and the chirping noise is gone! Quote Link to comment Share on other sites More sharing options...
G B L Posted September 15, 2020 Share Posted September 15, 2020 There is a weep hole under the Pump pulley , sounds like you found it , Great Job. Quote Link to comment Share on other sites More sharing options...
