doogymon Posted August 7, 2020 Share Posted August 7, 2020 Hello TC'ers I popped out the floor D rings from the rear of the van. The D rings helps secure the vinyl floor. I lifted the floor and found moisture underneath between the steel and the foam underlying (white foam is the backing for the black vinyl). Not a ton of moisture but it seemed cold and damp and sweaty as if someone wiped a wet towel on the paint. Is the cargo mat a recipe for premature corrosion of the van's floor? Appreciate your guidance. Doog Quote Link to comment Share on other sites More sharing options...
MLB Posted September 30, 2020 Share Posted September 30, 2020 Probably depends on where you are. Maybe in the right climate conditions. Here in the midwest the only time mine was wet was something spilling and ending up under there. I just pull mine up every 6 months or so and check. But other than once, no moisture. Quote Link to comment Share on other sites More sharing options...
