Cargo Mat moisture
Hello TC'ers
I popped out the floor D rings from the rear of the van.
The D rings  helps  secure the vinyl floor.
I lifted the floor and found moisture underneath between the steel and the foam underlying (white foam is the backing for the black vinyl).
Not a ton of moisture but it seemed cold and damp and sweaty as if someone wiped a wet towel on the paint.
Is the cargo mat a recipe for premature corrosion of the van's floor?
Appreciate your guidance.
Doog
Probably depends on where you are.  Maybe in the right climate conditions.  Here in the midwest the only time mine was wet was something spilling and ending up under there.  I just pull mine up every 6 months or so and check. But other than once, no moisture.
