Window won't go down
I have a 2016 Ford Transit connect.  My windows always operated.  this might be a coincidence but I engaged the child safety mechanism on the passenger slide door.  A few days later I flipped it back to normal position.  you can now open the door from the inside just as normal.  But I noticed that I cannot have my window go down it stays up.  Good thing it's not stuck down but is this part of the child safety lock mechanism or a separate issue and is there a procedure I need to do to get it to operate again.
Hi Ron - Did you solve this issue?  I am curious, as on my 2018 wagon I have a similar problem, the sliding door window switches do not work for the power windows, but I can move them up/down from the driver door control. I can lock the windows or unlock them, but this does not impact use of the rear window controls.
