toml55421 Posted June 16, 2019 Share Posted June 16, 2019 Does anyone know how to replace the cabin air filter on a 2018 Transit Connect Titanium LWB with rear climate control? I know the filter is shaped similar to an upside down basket coffee filter and is located under the driver's front seat.... Any help is very much appreciated. Quote Link to comment Share on other sites More sharing options...
G B L Posted June 17, 2019 Share Posted June 17, 2019 Here is a photo of the filter housing . It is accessed from the passenger foot well and is not to hard a job , Rock aut and many others have the filter. Quote Link to comment Share on other sites More sharing options...
Eddy Kilowatt Posted June 17, 2019 Share Posted June 17, 2019 GBL, that's the front cabin air filter, which is replaceable. Tom seems to be asking about the rear cabin air filter, which is indeed under the driver's seat where the rear cabin air blower is located. It's porous foam and seems washable (i.e. mine didn't dissolve when I washed it) so shouldn't actually need replacing too often. It's been awhile since I did mine but the procedure is straightforward... slide the driver's seat forward, go in thru the left sliding door with a good light, there's one small screw to remove that locks it in place and then (IIRC) a tab to squeeze at which point you can rotate the cover a few degrees to release it. Wash the element, vacuum under the seat while the element's drying, reverse steps to re-assemble, and you're done. Charlie722 1 Quote Link to comment Share on other sites More sharing options...
Eddy Kilowatt Posted June 17, 2019 Share Posted June 17, 2019 Quote Link to comment Share on other sites More sharing options...
toml55421 Posted June 18, 2019 Author Share Posted June 18, 2019 Thanks to GBL and Eddy Kilowatt. You both alerted me to the existence of a front cabin air filter and Eddy Kilowatt described perfectly how to service the rear cabin air filter. Bravo to both of you! Quote Link to comment Share on other sites More sharing options...
Charlie722 Posted December 30, 2020 Share Posted December 30, 2020 Eddie Kilowatt, you mentioned having to squeeze a tab to rotate the cover to release it. Where is that elusive tab? I cannot see or feel it, and I can see from the condition of the filter through the grille that it REALLY needs a good cleaning or replacement! Interesting that the owner's manual never mentions this filter or the need to clean it periodically. Quote Link to comment Share on other sites More sharing options...
mculbert Posted November 6, 2024 Share Posted November 6, 2024 Sorry to revive an old thread, but it appears Ford has discontinued this filter. I had on order from Autonation for a couple weeks, and they just cancelled it yesterday. Mine seemed super dirty, but this is a synthetic filter, so it's washable. It cleaned up nicely with warm water and a bit of dawn dish soap. Quote Link to comment Share on other sites More sharing options...
