Rjgreen Posted April 16, 2019 Share Posted April 16, 2019 (edited) My van won’t start I have been told may be ecu when I turn the key nothing happens on the dash where the mileage should be there is 4 dashes if I disconnect the battery and then reconnect it the mileage reappears but as soon as I turn the key it goes again is there any wires I can check or something I might be missing ? tia Mira at 53 plate Edited April 16, 2019 by Rjgreen Forgot to say what van I had Quote Link to comment Share on other sites More sharing options...
G B L Posted April 17, 2019 Share Posted April 17, 2019 Have you jumped the starter to see if the engine turns over? Check all the grounds first. Quote Link to comment Share on other sites More sharing options...
WillMartin Posted April 20, 2019 Share Posted April 20, 2019 What year and how long did you disconnect the battery? You have to disconnect the battery for five or ten minutes, I don't remember which. There's another work around if that doesn't solve the problem, but I don't know what it is. The battery disconnect worked the one time I needed to reset things. Quote Link to comment Share on other sites More sharing options...
