Almo Posted March 18, 2019 Share Posted March 18, 2019 As above required please. I did a search on here but couldnt find anything. Fitting new front wheel bearing and half shaft tomorrow and I cant find it listed in my Haynes manual. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
G B L Posted March 18, 2019 Share Posted March 18, 2019 The SKF book says 59 ft Lbs and then 90 degrees with a oem new nut. Quote Link to comment Share on other sites More sharing options...
Almo Posted March 18, 2019 Author Share Posted March 18, 2019 5 hours ago, G B L said: The SKF book says 59 ft Lbs and then 90 degrees with a oem new nut. Thank you for that. The only other reference I could find was this part supplier who lists it as 207ft/lb. Big difference! https://www.go-parts.com/ps-product.php?product=7530257&name=2010 Ford Transit Connect Wheel Bearing - Front MPA&year=2010&make=Ford&model=Transit Connect&parttype=Wheel Bearing&sku=2F7B968 Quote Link to comment Share on other sites More sharing options...
Almo Posted March 19, 2019 Author Share Posted March 19, 2019 I went with 200ft/lb and it still spins so cant be too tight! greg_lanz 1 Quote Link to comment Share on other sites More sharing options...
JRMoyer Posted June 25, 2024 Share Posted June 25, 2024 What is the front axle torque specs for a 2020 Ford Transit 250 with 6 lug - Heavy duty front axles Finding multiple specs that conflict Quote Link to comment Share on other sites More sharing options...
