Anyone seeing strange rust marks around window plastic trim (and trunk trim)?
govandlaw
If it is rust, that is a warranty issue.  Have the dealership look at it.  Let their techs pull panels and peek under with a flashlight.  Look on top.  Do you have roof rails, or caps over the little holes.  If any water is getting in, that would be a slow leak would develop.  Then that moisture could trap between the roof & headliner, causing untreated metal to rust.  With motion, the rusty water leaks down to where it is visible to you.
