It looks like you just need to bypass/overide the door ajar switch. My guess is the switch pulls the signal going to the BCM to ground. I don't have the schematic for the latch mechanism.
It may be easier to modify the wiring at the BCM. It is behind the glove box and very easy to access. Maybe install a switch that grounds the door ajar signals.
Expand
Pretty much my thinking. I believe I could use a switch or switches to jumper the door ajar switches either at one location or multiple locations.
Or simply jumper the sensors/switches. If I install new lights for the cargo area and use a separate source of power then the annoying outside lights would never come on when you open one of cargo doors. As it should be.
Would like to have my plan in place before I start to modify the back area.
