Joe.S Posted September 8, 2017 Share Posted September 8, 2017 The intercooler is split on my Ford Transit Connect 2004 1.8 Diesel. Can I replace it with the intercooler below: http://www.carparts4less.co.uk/cp4l/c/Ford_Transit+Connect_1.8_2004/p/car-parts/cooling/car-cooling-parts-and-car-heating/intercooler/?229590070&1&1b2296bbfc50f136f3e782983d1aee91536a9409&000207 I don't think the intercooler above has a 'Thrust Sensor Outlet'. Does that matter? Attached are two pictures that show the engine and the current intercooler. Any help gratefully received. Thanks. Quote Link to comment Share on other sites More sharing options...
G B L Posted September 9, 2017 Share Posted September 9, 2017 Is everything the same on the new intercooler except the Thrust sensor port ? If it is then the Thrust sensor port could be added to it . Quote Link to comment Share on other sites More sharing options...
Joe.S Posted September 11, 2017 Author Share Posted September 11, 2017 Thanks, G B L. The new intercooler arrived today. It has a hole, or a 'port', where the thrust sensor should go... so just screw the old sensor into the new port? Quote Link to comment Share on other sites More sharing options...
G B L Posted September 12, 2017 Share Posted September 12, 2017 Remove it carefully and use a small amount of pipe sealant on the thread if there is no gasket. looks like an easy fix Quote Link to comment Share on other sites More sharing options...
