Bart Luther Posted July 18, 2017 Share Posted July 18, 2017 I would like to add a small light bar to a front license plate bracket I purchased. What is the best way to get power to it . 2016 transit connect wagon. I want a separate switch to only turn on when needed . Should I go straight to the battery or tap a fuse ? Thanks for any advise! Quote Link to comment Share on other sites More sharing options...
Beta Don Posted July 18, 2017 Share Posted July 18, 2017 If you want a switch for it, then it would be easiest to tap a fuse on the inside fuse panel than to mess with going to the battery. They make a 'fuse tap' which replaces a fuse and still keeps the original fuse in the circuit as well as adding a second fuse for your new circuit. I bought 5 of them on eBay for less than $3 when I added running lights to my fog lights Don James Stanley 1 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted July 25, 2017 Share Posted July 25, 2017 The only problem is people backing into parking spaces and knocking off your lights. Quote Link to comment Share on other sites More sharing options...
