Grab Handle for Lift Gate
Installed a grab handle on my lift gate to assist in closing it.  Works real well.  I bought a handle from "attwood" item #2054-5, off Amazon for $13.00.  It is attached using rivet nuts, and Philip head bolts, so if it has to be replaced, it will be very easy.  The handle is for marine environments so should hold up well.
Nice Job! If the rivet nuts you used are aluminum put some grease on the screws , that  will make sure they will come out in the future. With the air pattern the TC generates  that area gets a lot of road dirt.
