Doffy Posted February 1, 2017 Share Posted February 1, 2017 Hi, just got my first Ford Transit Connect 2007 1.8 75hp My question is, the mark on the rear says tdci.... but I think i might have the tddi engine? My engine code is R2PA.... Anyone know ehat kind of engine it is? And what is the diffrence between this 75hp and the 90/115hp? If i get a ecu tune up i get 90hp... Why so? Are the injector diffrent? turbo? Can i swap a 115hp injector/turbo to my engine and get 115hp? Best regards from Chris, Norway Quote Link to comment Share on other sites More sharing options...
mrtn Posted February 1, 2017 Share Posted February 1, 2017 It's TDCi, the "new" type. TDDi is the old type and was discontinued in 2006. It's considered the most durable one. The power options are defined by ECU mapping and turbo variants, yes. Quote Link to comment Share on other sites More sharing options...
Doffy Posted February 1, 2017 Author Share Posted February 1, 2017 So the only difference between the 75hp and 90 - 115hp is just the turbo? Possible injectors also? If it is the same engine configuration i thought i would get 115hp with a ecu tune but i "only" get 90hp.... Also do you know if the egr pipe can be blocked or will it cause engine fault/limp home mode? Quote Link to comment Share on other sites More sharing options...
mrtn Posted February 1, 2017 Share Posted February 1, 2017 I am not sure about injectors. There have been different injector systems throughout the years, Siemens, Delphi and Bosch. The 75 and 90 hp are just injector map difference. I think the most powerful one has VNT turbo. I know that the later models need some modification for EGR blanking, TDDi is dumb and can be blanked with the €2 plate. You can get plenty of diesel info in facebook group "transit connec'ed". Quote Link to comment Share on other sites More sharing options...
