pvguy1216 Posted December 15, 2016 Share Posted December 15, 2016 Hello, I'm in the US and have a 2012 Transit Connect. The upper latch on the right (passenger) side rear door will not relaease. I have tried all the various locking/unlocking options, opened the access to determine how the latch works, all without success. I have removed the two screws holding the latch bracket so that I can open and close the door and the center (handle) latch is working. has anyone experienced this problem and, if so, how did you resolve it? I cannot determine how to remove the cable or rod that operates the latch. Does anyone have a diagram showing this latch? Thank you, Tom Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 15, 2016 Share Posted December 15, 2016 This may be a recall item. Check with your dealership. Quote Link to comment Share on other sites More sharing options...
pvguy1216 Posted December 16, 2016 Author Share Posted December 16, 2016 Hello Fifty150, I've looked into this and it does not seem to be a recall issue. there was a recall on sliding, not rear, doors..... Quote Link to comment Share on other sites More sharing options...
ActiveIndy Posted December 30, 2018 Share Posted December 30, 2018 Any resolution to this issue? I also have the same problem....the upper latch on the passenger side won't release. MIne is a 2010, but should be same mechanism.... Quote Link to comment Share on other sites More sharing options...
