BossMan Posted July 9, 2016 Share Posted July 9, 2016 First timer here... Both the left and right side turn signals blink fast. No bulbs are burned out, and I don't have any LED bulbs. Any tips on where to start? Quote Link to comment Share on other sites More sharing options...
robertlane Posted July 9, 2016 Share Posted July 9, 2016 is this for your 2013? Could the blinker relay be bad? Quote Link to comment Share on other sites More sharing options...
103west43rd Posted July 9, 2016 Share Posted July 9, 2016 Hello BossMan. There is not too much in the turn signal circuit. The turn signal switch completes the circuit for the left or right side for the Generic Electronic Module (GEM). The GEM then sends the voltage to the turn signal bulbs. The GEM also controls the speed of the blinking. The GEM controls numerous items in the van, so it is a last resort to replace. Let me look for other possible reasons. operating engineer O/O 1 Quote Link to comment Share on other sites More sharing options...
103west43rd Posted July 10, 2016 Share Posted July 10, 2016 BossMan, three questions. Have you had the Transit Connect since new, or did you just get it with the turn signal blinker problem? Are there any trouble codes? What are the turn signal bulb numbers? operating engineer O/O 1 Quote Link to comment Share on other sites More sharing options...
BossMan Posted July 10, 2016 Author Share Posted July 10, 2016 22 hours ago, 103west43rd said: BossMan, three questions. Have you had the Transit Connect since new, or did you just get it with the turn signal blinker problem? Are there any trouble codes? What are the turn signal bulb numbers? Its a company vehicle, bought new. Recently assigned to me though. I'll check the bulb model numbers when I get home. Quote Link to comment Share on other sites More sharing options...
Byron Posted October 23, 2017 Share Posted October 23, 2017 Had the same issue and made me nuts till I found problem. It is probably the bulb holder for TS. What I found is that the bulb holder wears through where it is in contact with bulb. You can solve by slightly bending wire on bulb or replacing holders. My dealer stocks a big bag of holders so they are aware of issue. operating engineer O/O 1 Quote Link to comment Share on other sites More sharing options...
