japie Posted July 8, 2016 Share Posted July 8, 2016 For the past few months the instrument cluster of my 2005 Connect has been working intermittently only. The alternator light stays on all the time but the battery does not discharge. The speedo and rev counter only seem to show readings when I take my foot off the gas. Occasionally the ABS light will flicker on and off. I have more or less ruled out a wiring problem and have replaced the instrument cluster itself. Can anybody help, please ? Quote Link to comment Share on other sites More sharing options...
mrtn Posted July 8, 2016 Share Posted July 8, 2016 The cluster problems are common. I had mine repaired because one power pin was broken. Quote Link to comment Share on other sites More sharing options...
robertlane Posted July 9, 2016 Share Posted July 9, 2016 On 7/8/2016 at 5:11 AM, mrtn said: The cluster problems are common. I had mine repaired because one power pin was broken. What did the repairs entail? How much did it cost to repair it? Quote Link to comment Share on other sites More sharing options...
mrtn Posted July 9, 2016 Share Posted July 9, 2016 I think it was €90, the guy resoldered all contacts and replaced the temperature indicator motor because it got damaged when removing the needle. Quote Link to comment Share on other sites More sharing options...
mrtn Posted July 9, 2016 Share Posted July 9, 2016 Wait. Did you replace the whole instrument cluster with a new one and it behaves exactly the same? Quote Link to comment Share on other sites More sharing options...
