jwest Posted January 31, 2016 Share Posted January 31, 2016 So, here's what a SWB van looks like with 16x7 40mm offset Sparco Terras. The tires are the original 215/55/16 Contis. Hope this is helpful... JW LostInTransit and MarkMcCoskey 2 Quote Link to comment Share on other sites More sharing options...
jwest Posted February 13, 2016 Author Share Posted February 13, 2016 Thanks LostIn, My previous experience with plastic centering rings is that they are fine until you get them hot-enough melt. Even then, they get tossed and you rely on the taper in the lugnuts to center the wheel. (I've only ever seen them get that hot running multiple really hard laps at a race track.) I went back and forth on going to the 225/50's as well. I was concerned about rubbing the front inner fender at full lock, but it really does look like there's room. I plan to try them when the current tires are done. I look forward to not only the increase contact patch, but also the 1% change in final drive ratio. Seems like lower gearing could make the van even more fun :-) Thanks again, JW LostInTransit 1 Quote Link to comment Share on other sites More sharing options...
G B L Posted February 13, 2016 Share Posted February 13, 2016 Here's a Tire Chart with all the 16" tires and the Diameters and the plus and minus percentages jwest 1 Quote Link to comment Share on other sites More sharing options...
i86hotdogs Posted March 22, 2019 Share Posted March 22, 2019 I've been eyeing those wheels online. They look amazing underneath a white body. Now I just need to cough up $675 to get me a set... Quote Link to comment Share on other sites More sharing options...
