Sign in to follow this
Osco
2015 Cabin Air Filter
Ok I got one from Napa, now to find the thing In the Droid..
I find this odd, I googled and got Video's on changing the Gen 1 filter.
I googled every wording I could find on the 2014 and 2015,, not a single picture of the Gen 2 filter location.
The panel under the windshield is one piece from fender to fender, so not there, I will Look behind the glove box.
Week two, broke my windshield,,Bummer. I hate rock trucks.
I will report back,
Oh and I changed my oil and found the reset page, but It does not show how to reset the mile Interval between oil changes.
I assume Its set to more than 5k miles as at exactly 5k It did not sound the 'Oil Change" alarm :P
Edited by Osco
Odd, lifted the panel under the windshield, did not see a filter,
behind the glove box,,nothing.....
Remove the Glove box and it is visible on the right side of the heater with the removal of 6 screws You might have to pull some plugs on the Electric box if so disc the battery
post-4748-0-07702000-1454170451_thumb.jppost-4748-0-41074500-1454170480_thumb.jp
Edited by G B L
Thank You very much G B L
2015 XLT LWB Wagon..got it in..cabin air filter...
Two plastic clips pop out the cover panel below glove box..
I squeezed the glove box so it would hang way down...did not remove it.
Filter door uncoils..no screws..old out..squeezed/acordian style the new filter..shoved it in and it instantly expanded....
Cover panel clipped back in..re-hung the upper glove box stops and reinserted the two clips holding the lower cover panel in...
DONE.
Good another way is to pull the kick panel and you can get to it with out dropping the glove box
I have a 2017 TC and it's definitely behind the glove box. Even with location images from the ford dealership I can't figure out how to get to the filter.
