I just joined the group and thought I'd post up the current TSB's. I actually don't have a TC yet but am taking delivery on Monday 8/2. I have some pretty good resources so if I can be of assistance to someone just give me a shout. I've noticed some of the posts here pertain to these TSB's. I can post the complete bulletin on an as needed basis.
Here is the current list:
Technical Service Bulletins
2010 TRANSIT CONNECT - US (English)
The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply.
10-15-3
THUMPING/KNOCKING NOISE - REAR BRAKES
10-15-1
P07XX, P0642, P0138, P0141, P0219 AND/OR ERRATIC SHIFTING AND/OR ERRATIC SPEEDOMETER - BUILT ON OR BEFORE 12/29/2009
10-11-4
CLIMATE CONTROL BLOWER MOTOR - CONTINUOUS OPERATION / INOPERATIVE ON ONE SPEED - A/C COMPRESSOR INOPERATIVE - BUILT ON OR BEFORE 8/7/2009
10-9-6
CREAK NOISE FROM REAR - WITH BRAKES APPLIED
10-4-9
VARIOUS WATER LEAKS
10-1-10
BLACK RUBBER CARGO MAT OFFENSIVE SMELL
09-22-2
LATERAL PLAY AND/OR RADIAL NOISE IN TELESCOPING STEERING COLUMN
09-20-8
PASSENGER WIPER ARM INTERFERES WITH DRIVER ARM IN PARK POSITION
09-19-18
REAR CARGO DOOR RATTLE - BUILT BEFORE 6/1/2009
Wow, picked my TC up at 3:00 this afternoon with 50 miles on the clock and on the way home, 20 miles away, I'm getting the rear brake knock. So here I am using my own recall info. Supposedly it quits knocking after a "break-in" period. Well it's loaded pretty good and I have 500 miles to run tomorrow so we'll just see about that!
Awesome the hear your have access to TSBs. I'm interested in those that pertain to a 2010 Transit Connect XLT Wagon. If I must narrow my items of interest, they would be a) driveline / steering wheel vibration (or rumble, roughness, drumming, grinding) under engine load/acceleration, and b) sliding door power lock noise. I'll hold a good thought for your reply. Thanks!
