2013 Focus to 2014 TC Wheels
I did some checking on this. I went on tirerack.com and looked up 18 inch tires for the TC and the tires I have on the rims came up. The tires from the factory are rated 97/1602 lbs max each. The tires I have on the rims are rated 95/1502 lbs max each. The rims are 1600 lbs max each. The GVWR is 5270 lbs and the curb weight is 3618 lbs. looks like I'm good to go. as far as clearing the suspension I will try this weekend.
Focus ST it sounds like ;)
The bolt pattern is probably the same, but I don't think they will clear the suspension?
I put them on and they cleared everything suspension wise. The truck already had a rough ride before the rim change, but after it was like riding in a tank. you could feel every bit of the road. I took them off and put the factory ones back on. up to 18's is too much of a change.
Hello EmoMorales. Thanks for the posting. Our 2014-2015 Transit Connect forum members now know a Ford wheel and tire combination that fits. They look very nice and sure fill up those wheel well's!.
Your Welcome, just trying to help.
The Rims are 18 X 8 with a 42MM offset. The tires are 235/40R18 with a 25.4" Diameter. It also looks as if you can put a 235/45/18 with a 26.33" Diameter and a 225/45/18 with a 25.97" Diameter on that rim and still have room in the wheel wells. The original tires had 25.31 diameter with somewhere between 50MM and 53MM offset.
post-4816-0-95325300-1431905057_thumb.jp
Edited by EmoMorales
  • 7 years later...
On 4/11/2015 at 3:05 PM, EmoMorales said:
Have some rims from my 13 focus I want to put on my 14 TC. They are 235/40R 18. I know the bolt patern is the same. Anyone done this before?
I’m super late to this conversation, but I’m currently in the sane dilemma. Did it continue to work? We’re they okay on the TC? I have a 2017 and have 2016 Focus 18” I wanna put on my TC. How are they?
