FTCPNW Posted July 8, 2010 Share Posted July 8, 2010 There are two vent with rubber flaps above the rear door opening. What are they venting? the space between the head liner and the roof? is the what the other internal cargo area vents are doing? Which leads to my next question. I often use this van as a camper and this results in condensation over night. I would like to install a vent with a fan to help ventilate the van but since the roof is corrugated the options seem limited. I wonder if these other mystery vents could be modified to improve circulation? Open them up a little and add a small 12v fan??? This could also help keep the van cooler if it's in the the blazing hot summer sun. To help with this I have just tinted the window which cuts the heat exposure in half - per window. I have a windshield sun block and factory tint on rear window. Also I just ordered 5mm closed cell foam insulation wrapped in aluminum foil that I will coat the inside with it has a R value of 15 and It reflects 97% of radiant heat. insulation link. Quote Link to comment Share on other sites More sharing options...
Willie Posted July 8, 2010 Share Posted July 8, 2010 I hear ya! I’d be satisfied with partly opening rear windows. Quote Link to comment Share on other sites More sharing options...
rlschow Posted July 12, 2010 Share Posted July 12, 2010 Interesting product, the 5mm insulation. Did you get the garage door kit or the big roll? Hard to believe something that thin achieves R-15, but I noticed in their technical specs that it got that rating by testing it in the center of a 2x6 studwall; and they mention that it performs better with a 1/2" to 3" air space. I suppose if you stick it to the top of the headliner that would leave some air space above. Are you going to do your side walls and panel over? Quote Link to comment Share on other sites More sharing options...
4DThinker Posted July 13, 2010 Share Posted July 13, 2010 Those vents above the door openings look to be the outlet for the round plastic vent inlets on the rear corner pillars just inside the doors. Probably serve at best to equalize pressures between inside and out. One thing I'd love to have is a roof vent of some kind. My previous car has a sunroof that I'd crack open after the car had been parked in the sun to let all the heat escape out the top. It's a shame the TC's roof is ribbed. I'd seriously consider adding an electric slide-open sunroof if it was possible. Quote Link to comment Share on other sites More sharing options...
JJ Cobra Posted July 14, 2010 Share Posted July 14, 2010 This is what I did to get air flow in the back cargo area. The vents open either way to scoop air in or suck it out. I got them off of Ebay for $10.00 each. Quote Link to comment Share on other sites More sharing options...
FTCPNW Posted July 20, 2010 Author Share Posted July 20, 2010 On 7/12/2010 at 6:44 PM, rlschow said: Interesting product, the 5mm insulation. Did you get the garage door kit or the big roll? Hard to believe something that thin achieves R-15, but I noticed in their technical specs that it got that rating by testing it in the center of a 2x6 studwall; and they mention that it performs better with a 1/2" to 3" air space. I suppose if you stick it to the top of the headliner that would leave some air space above. Are you going to do your side walls and panel over? I got the 4' x 25' roll for $60. I will do a double layer on top, and where is it a single sheet of metal on the sides, maybe even the floor. I will panel it eventually once I figure out some other details. I tried to post some images but it wasn't working for me. so you can see the pictures in my gallery. Quote Link to comment Share on other sites More sharing options...
cvet Posted September 21, 2010 Share Posted September 21, 2010 I see you have a dive flag sticker on the rear of your TC. Are you going to do any type of build out inside for caring of SCUBA gear??? Quote Link to comment Share on other sites More sharing options...
framebinder Posted October 22, 2010 Share Posted October 22, 2010 (edited) I was told that the vents in the rear corner pillars are connected to a one way valve to release the air pressure when we close the door. Clever, huh? I suppose a person could rig an exhaust vent to this. Edited October 22, 2010 by framebinder Quote Link to comment Share on other sites More sharing options...
