Hi, David Reddy, 2010 XLT Wagon
David Reddy
Hi,
I got my 2010 Transit XLT about a year ago. It had 75K miles on it when I got it and I've put 18K on it since. I live in Tampa and use the Transit for my regular vehicle. It has been great so far, just regular maintenance except for my current need for a driver side sliding door lock actuator. I also keep losing hubcaps, a common complaint, I think.
Assuming you care about having hubcaps, I suggest you replace with a cheap set form Amazon. Just make sure they have adjustable wire retainers and they will stay on a lot better. The stock hubcaps will also work okay provided you are careful to press then on evenly all around the circumference.
Hi,
Welcome to the Ford Transit Connect Forum - my home state is Florida, opposite coast though.
