KeyWestLes Posted August 27, 2014 Share Posted August 27, 2014 Vehicles Affected: Nearly 370 model-year 2014 Ford Transit Connect vans manufactured between March 1, 2014, and May 15, 2014 The Problem: The affected vehicles may have a brake reservoir cap that does not have the required text advising owners which brake fluid the vehicle uses. This could result in someone adding the wrong brake fluid, causing damage to the brake system seals and, in turn, brake fluid leaks; this could lengthen stopping distances and increase the risk of a crash. The Fix: Ford notified owners on July 14, and dealers will replace the brake reservoir cap with the correct one for free. What Owners Should Do: Owners can call Ford at 800-392-3673, the National Highway Traffic Safety Administration's vehicle safety hotline at 888-327-4236 or go to www.safercar.gov for more info. Need to Find a Dealer for Service? Go to Cars.com Service & Repair to find your local dealer. Quote Link to comment Share on other sites More sharing options...
Johnyguy Posted August 27, 2014 Share Posted August 27, 2014 Vehicles Affected: Nearly 370 model-year 2014 Ford Transit Connect vans manufactured between March 1, 2014, and May 15, 2014 The Problem: The affected vehicles may have a brake reservoir cap that does not have the required text advising owners which brake fluid the vehicle uses. This could result in someone adding the wrong brake fluid, causing damage to the brake system seals and, in turn, brake fluid leaks; this could lengthen stopping distances and increase the risk of a crash. The Fix: Ford notified owners on July 14, and dealers will replace the brake reservoir cap with the correct one for free. What Owners Should Do: Owners can call Ford at 800-392-3673, the National Highway Traffic Safety Administration's vehicle safety hotline at 888-327-4236 or go to www.safercar.gov for more info. Need to Find a Dealer for Service? Go to Cars.com Service & Repair to find your local dealer. I wish every recall would be this minor and hope won't be any more after this. Quote Link to comment Share on other sites More sharing options...
daneli Posted August 27, 2014 Share Posted August 27, 2014 From what I've read, the vehicles involved were all shipped to Puerto Rico: "The next recall is strictly on paper. Ford is recalling 368 Ford Transit Connect vehicles from the 2014 model year that are located in Puerto Rico because they have the European brake reservoir cap label, instead of the mandated US version. Dealers will replace the decal on the affected models." [source:http://www.autoblog.com/2014/07/08/ford-6-recalls-12-vehicles-100000-cars/] Quote Link to comment Share on other sites More sharing options...
'14 Connect Posted February 12, 2020 Share Posted February 12, 2020 On 8/26/2014 at 5:43 PM, KeyWestLes said: Vehicles Affected: Nearly 370 model-year 2014 Ford Transit Connect vans manufactured between March 1, 2014, and May 15, 2014 The Problem: The affected vehicles may have a brake reservoir cap that does not have the required text advising owners which brake fluid the vehicle uses. This could result in someone adding the wrong brake fluid, causing damage to the brake system seals and, in turn, brake fluid leaks; this could lengthen stopping distances and increase the risk of a crash. The Fix: Ford notified owners on July 14, and dealers will replace the brake reservoir cap with the correct one for free. What Owners Should Do: Owners can call Ford at 800-392-3673, the National Highway Traffic Safety Administration's vehicle safety hotline at 888-327-4236 or go to www.safercar.gov for more info. Need to Find a Dealer for Service? Go to Cars.com Service & Repair to find your local dealer. Ohhhh big problem,,,I wish everything was that easy Quote Link to comment Share on other sites More sharing options...
