Raincity Posted August 30, 2013 Share Posted August 30, 2013 Would like to fit in something a little larger than a 5.25". Haven't taken it apart yet to see what is up but wondered if anyone has? Quote Link to comment Share on other sites More sharing options...
mrtn Posted August 31, 2013 Share Posted August 31, 2013 I cut the door sheet metal to fit 5x7" ovals, which was no problem. It really depends on the magnet size more than the diameter. Quote Link to comment Share on other sites More sharing options...
Raincity Posted August 31, 2013 Author Share Posted August 31, 2013 If you managed to fit a 5x7", a 6.5" could probably be done. I'll have to check the depth to see. thanks Quote Link to comment Share on other sites More sharing options...
mrtn Posted September 2, 2013 Share Posted September 2, 2013 The cone will be off the center of the door grill, because the OEM speaker is really close to the rigid frame parts. Quote Link to comment Share on other sites More sharing options...
Raincity Posted September 3, 2013 Author Share Posted September 3, 2013 The cone will be off the center of the door grill, because the OEM speaker is really close to the rigid frame parts. Opened up the door today and you were right. OEM speaker is already off-center slightly so cutting in a 6.5 would only make it worse since you would have to avoid other bits. Quote Link to comment Share on other sites More sharing options...
Seriously Limited Posted September 3, 2013 Share Posted September 3, 2013 Opened up the door today and you were right. OEM speaker is already off-center slightly so cutting in a 6.5 would only make it worse since you would have to avoid other bits. Yes, this is an annoyance, especially with the proximity of the grille to the armrest. I have a nice pair of Infinity's from my BMW that I wanted to fit, but realised that they would have to mount through the door card to have any chance of fitting. T230 Limited 110 diesel, Clifford alarm, sat-nav, rear view camera, HID headlamps, front park sensors, leisure battery with onboard charger, fully fused 12V distribution, mains distribution, diesel night heater, carpeted ply floor, insulation, LED down-lighting. Quote Link to comment Share on other sites More sharing options...
