skippyelwell Posted March 25, 2024 Share Posted March 25, 2024 2014 TC 180,000kms, it doesn't matter how many times I reset the clock it won't work, I got it working last summer and it was good for a few months but then I had to disconnect the battery to install a new one and it went back to the way it was when I first got it. It advances 2-3 min per day. Do I have to replace the whole unit to fix it? Thanks Quote Link to comment Share on other sites More sharing options...
G B L Posted March 26, 2024 Share Posted March 26, 2024 When mine does that it is usually a result of a low voltage start. I disconnect the bat for 5 Min's and that usually triggers a correct reset soon. This has been happening to me for 10 years . Good luck and keep us posted. Fifty150 and skippyelwell 2 Quote Link to comment Share on other sites More sharing options...
skippyelwell Posted March 30, 2024 Author Share Posted March 30, 2024 On 3/26/2024 at 8:25 AM, G B L said: When mine does that it is usually a result of a low voltage start. I disconnect the bat for 5 Min's and that usually triggers a correct reset soon. This has been happening to me for 10 years . Good luck and keep us posted. Thank you sir, that did the trick. It's a small thing but it's just enough irritate. Quote Link to comment Share on other sites More sharing options...
