UrAlly Posted November 12, 2022 Share Posted November 12, 2022 Hey hi, 2nd owner from a fleet with some quirks to figure out. 1) they had a security system installed and all it took to unhook it was a yank of one wire under the dash - sounds fishy, and the security lights still come on. ... it's killed the start once. Dealership said, it's "fine". 'should' work ... ? second situation, no one can figure out where the trickle drain on the battery is coming from after pulling individual fuses, checking all points, but when it rains, The TC won't start the next day. Anyone else had that? We haul, all livestock and animals in our van. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted November 12, 2022 Share Posted November 12, 2022 On 11/12/2022 at 9:49 PM, UrAlly said: Hey hi, 2nd owner from a fleet with some quirks to figure out. 1) they had a security system installed and all it took to unhook it was a yank of one wire under the dash - sounds fishy, and the security lights still come on. ... it's killed the start once. Dealership said, it's "fine". 'should' work ... ? second situation, no one can figure out where the trickle drain on the battery is coming from after pulling individual fuses, checking all points, but when it rains, The TC won't start the next day. Anyone else had that? We haul, all livestock and animals in our van. Expand Welcome aboard. I'm here in The City. San Francisco. I want to be able to guess, that the aftermarket alarm is the source of your problems. If you can get it "uninstalled", and not just pull out 1 wire under the dash, and return the van to stock..... Or troubleshoot the security device, plug that wire back in, and get it to work as intended...... Some security systems disable the ignition. Maybe it's the security device that's not allowing the van to start when it's raining. UrAlly 1 Quote Link to comment Share on other sites More sharing options...
