Willygee Posted September 5, 2022 Share Posted September 5, 2022 When our Transit connects G2 2.5L are on a driveway with slight incline (nose up) how does the oil dipstick level read compared to a level surface. Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted September 6, 2022 Share Posted September 6, 2022 On 9/5/2022 at 11:54 PM, Willygee said: When our Transit connects G2 2.5L are on a driveway with slight incline (nose up) how does the oil dipstick level read compared to a level surface. Expand You will rarely be on a perfectly level surface. But the grade on your driveway will not give you a good dipstick reading. The dipstick allows for a wide margin. On a lot of cars. 1 quart. Don't worry too much. As long as you are not consistently below the low range. On some cars, like Mercedes, Subaru, Hyundai, and 1970's era Fords, burning oil was a real problem. On some modern Fords, burning oil is still a real problem. I haven't heard about it with the 2.5 liter engine. Oil leaking is not a known issue either. Unless a lube shop did something wrong. Yes. Do check your oil. Do it as much as you need to, to feel comfortable. A dipstick is not a precision measuring device. It's still good enough for you to see how dirty the oil looks. Not that the naked eye is really able to see how contaminated the oil is. You can always hold it to your nose to check if the oil smells bad or burnt. Just don't taste test it. Quote Link to comment Share on other sites More sharing options...
Willygee Posted September 28, 2022 Author Share Posted September 28, 2022 Reads 1/4" from top of diamonds on driveway incline. Level surface(my garage)reads top of diamonds. Quote Link to comment Share on other sites More sharing options...
