Help with a part I.D. on my 2011 Transit Connect
chipD
Have you tried removing the existing part to see if the Ford part number is stamped on it? You might get lucky.
If not, bring the part to your local Ford dealer parts department. They should easily be able to tell you the part number since they have detailed parts diagrams.
Good luck!
