2010 Lights blowing fuse
Jimbosky
I am a huge fan of wiring diagrams, but you are looking for a bare wire so the diagram may not be very helpful. The diagram will show all the loads on the circuit and may help isolate parts of the sircuit. But I think you should start at the headlights and look for stray wire strands. Unplug the bulbs and measure the resistance between the terminals in the socket and look for a short (0 ohms).
thanks, but I was thinking of ohming  to ground on each wire on the head light switch or using a 12v bulb 12 v positive  on  one side and checking each headlight switch wire for a ground with the other side. I figured if I had a diagram I’d know which way to go.
