stephen51 Posted February 1, 2022 Share Posted February 1, 2022 Can't locate my Sensors. Can't find pictures or diagrams. Quote Link to comment Share on other sites More sharing options...
G B L Posted February 4, 2022 Share Posted February 4, 2022 If your TC is a 2.5 the O2 sensors are at both ends of the Converter which is the lowest part of the exhaust manifold. Quote Link to comment Share on other sites More sharing options...
stephen51 Posted February 6, 2022 Author Share Posted February 6, 2022 Can it be reached from top? Quote Link to comment Share on other sites More sharing options...
G B L Posted February 9, 2022 Share Posted February 9, 2022 It would not be an easy task as the rear of the engine is under the windshield cowl. The best way is to get the car up high enough to access them from underneath . You will need an Oxygen sensor socket to get them to move , use good Never-seize when you put them back. Quote Link to comment Share on other sites More sharing options...
