Punksuncle Posted January 28, 2022 Share Posted January 28, 2022 So quick resume on myself, I've been installing mobile electronics for decades.....multiple tvs, dvd, gps (before smart phones)... diagnosed electronic bugs in cars to semi trucks.....etc.etc...so I'm very familiar with findings shorts. So here is what I did, I switched my brake light bulbs to LED in the taillights and noticed my third brake light on the roof stopped working.....OR maybe it's been out the whole time? Anyone else have this issue? It will flicker if I tap it....... I think I'm buying a new assembly. 2016 SWB Thanks, Adam Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted January 28, 2022 Share Posted January 28, 2022 Probably a bad light or connection. The third brake light is an LED so it can have intermittent failure unlike an incandescent light. I changed my brake lights to LED without any issues. I eventually switched back to incandescent bulbs because I think they are brighter due to the tail light housing and reflector design. Quote Link to comment Share on other sites More sharing options...
Jseda Posted March 15, 2022 Share Posted March 15, 2022 On 1/27/2022 at 10:28 PM, Punksuncle said: So quick resume on myself, I've been installing mobile electronics for decades.....multiple tvs, dvd, gps (before smart phones)... diagnosed electronic bugs in cars to semi trucks.....etc.etc...so I'm very familiar with findings shorts. So here is what I did, I switched my brake light bulbs to LED in the taillights and noticed my third brake light on the roof stopped working.....OR maybe it's been out the whole time? Anyone else have this issue? It will flicker if I tap it....... I think I'm buying a new assembly. 2016 SWB Thanks, Adam That happened to me , the problem was the male pins solder to the board assembly, I did a hole I the plastic close to the pins and soldered it back to the board and no problems so far....! Quote Link to comment Share on other sites More sharing options...
dgotc Posted January 25 Share Posted January 25 (edited) On 3/15/2022 at 3:55 PM, Jseda said: That happened to me , the problem was the male pins solder to the board assembly, I did a hole I the plastic close to the pins and soldered it back to the board and no problems so far....! Hi, my high mount stop light is out and I was wondering if you could elaborate on where you drilled on the light and how that procedure went. I solder things professionally so I'd be comfortable tackling this with more info... Do you mean the light side connector pins? pins from the LED's? Thanks. Edited January 25 by dgotc Quote Link to comment Share on other sites More sharing options...
Jseda Posted January 29 Share Posted January 29 On 1/25/2025 at 11:33 AM, dgotc said: Hi, my high mount stop light is out and I was wondering if you could elaborate on where you drilled on the light and how that procedure went. I solder things professionally so I'd be comfortable tackling this with more info... Do you mean the light side connector pins? pins from the LED's? Thanks. Hello if you can post a picture of the back of your brake light where the 2 pins connector is located i could help you . Can't find a pictures from internet to show you Quote Link to comment Share on other sites More sharing options...
dgotc Posted Thursday at 05:46 PM Share Posted Thursday at 05:46 PM On 1/28/2025 at 10:52 PM, Jseda said: Hello if you can post a picture of the back of your brake light where the 2 pins connector is located i could help you . Can't find a pictures from internet to show you Thanks. I sealed it up and reinstalled until the replacement arrives. I believe the issue is the connector pins since the light briefly came on when it was wiggled. I decided to purchase a new unit from rockauto since the housing appeared to be cracked where the clear section meets the black plastic. I can post pics and experiment once I have replaced the light. Quote Link to comment Share on other sites More sharing options...
