PickyPoodle Posted December 27, 2021 Share Posted December 27, 2021 We had previously changed our front brake pads without issue. Yesterday we changed the rear without issue....so we thought...went to start it and it threw a brake fluid low warning code....reservoir is full and no leaks. Zero brakes at this point and at a loss. How do we resolve the issue and what could be the issue Quote Link to comment Share on other sites More sharing options...
G B L Posted December 29, 2021 Share Posted December 29, 2021 How did you retract the pistons? Did you turn the parking brake screws back in? Cycle the pedal several times very slowly. if you push too fast the front rear proportioning valve will prevent the fluid from . If that does not work you will have to bleed the brakes. Quote Link to comment Share on other sites More sharing options...
AnastasiaLowery Posted July 30, 2024 Share Posted July 30, 2024 It’s been a few years, but I'm wondering if you managed to resolve the issue. When I had a similar problem, it turned out to be air trapped in the brake lines, and I had to bleed the brakes to fix it. Quote Link to comment Share on other sites More sharing options...
