Mozer67 Posted October 31, 2021 Share Posted October 31, 2021 I have 2016 TC XL cargo that has the cutouts/caps on the front spoiler and wanting to see if anyone has installed the factory fogs in those spots? I’ve only had the van a few days so haven’t gotten down there and looked but do those need to be cut out or do they pop out? What about wiring and brackets? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted November 1, 2021 Share Posted November 1, 2021 You will need the lower plastic trim panel with the holes already cut out. Then there are additional pieces that the lamps mount on to. The lamps are sold separately. There are LED options. Now you will have problems. Adding the OEM wiring harness, connecting those lamps to the computer, adding the OEM dash switch, connecting the switch to the computer, then programming the computer to make it work. You can physically add the lower bumper trim piece and lamp assembly. No problem there. If it were me, I would run a new circuit, with a fused relay, and install a simple toggle switch in the van. Quote Link to comment Share on other sites More sharing options...
Mozer67 Posted November 6, 2021 Author Share Posted November 6, 2021 Thanks fifty. I think I’m going to go with your suggestion about running the new circuit. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted November 8, 2021 Share Posted November 8, 2021 I hope this gives you an idea of what you will need. I thought about it myself. Then just decided to bolt on an LED light bar instead. Quote Link to comment Share on other sites More sharing options...
