2015 Transit 250 Backup Camera Not Centered
Marky-Marc
So, since my 2020 Ford Transit Connect is in the shop indefinitely for a new Transmission (under warranty), because of the chip shortage, company gave me a 2015 Transit 250 to drive, which I really like.  A few issues with it, recall done on damper, but still rumbles when under load...anyway....my question today is...and I did google and search forum....to no avail...to see if anyone else had this similar issue....
So-IS THERE A WAY to adjust the camera so it is centered AGAIN? This camera/lines are WAY off.  I usually drive with my mirrors anyway, but...thought something was up with the Camera...so after driving back to my home office 800 miles, I decided to test it in an empty lot (car in picture parked next to me AFTER I had parked..)....
AS you can see, it has the Mirror display....photos attached....I seems like the camera is adjustable UP and Down...but that's about it-not side to side....any suggestions/tips?
Put some washers under the camera mount or license plate, on one side, to angle it differently.
Or maybe the screw is over tight on one side and could be loosened, and the other side tightened down more.
Edited by BSJBSJ
