Mark Shaw Posted September 6, 2021 Share Posted September 6, 2021 When I unlock my 2010 TC with the remote on the key fob, only one of the headlights lights up. This isn't a problem per se - both headlights work fine in normal operation - but I wonder if it means something? I have a friend with a newer TC that does the same thing. Quote Link to comment Share on other sites More sharing options...
mrtn Posted September 6, 2021 Share Posted September 6, 2021 Turn signal stalk switched? Quote Link to comment Share on other sites More sharing options...
Mark Shaw Posted September 6, 2021 Author Share Posted September 6, 2021 On 9/6/2021 at 7:56 PM, mrtn said: Turn signal stalk switched? Expand If you mean "are the headlights controlled by a switch on the turn signal stalk," no. It's on the dashboard to the left of the steering column. Quote Link to comment Share on other sites More sharing options...
mrtn Posted September 6, 2021 Share Posted September 6, 2021 (edited) On 9/6/2021 at 9:07 PM, Mark Shaw said: If you mean "are the headlights controlled by a switch on the turn signal stalk," no. It's on the dashboard to the left of the steering column. Expand No, I have a TC, I know where the switches are located, I mean is your turn signal stalk "ON" when the car acts this way? Edited September 6, 2021 by mrtn Quote Link to comment Share on other sites More sharing options...
Mark Shaw Posted September 6, 2021 Author Share Posted September 6, 2021 On 9/6/2021 at 10:05 PM, mrtn said: No, I have a TC, I know where the switches are located, I mean is your turn signal stalk "ON" when the car acts this way? Expand No, the turn signal stalk is in the default position. Quote Link to comment Share on other sites More sharing options...
ThatsMyDawg Posted November 10, 2023 Share Posted November 10, 2023 On 9/6/2021 at 7:27 PM, Mark Shaw said: When I unlock my 2010 TC with the remote on the key fob, only one of the headlights lights up. This isn't a problem per se - both headlights work fine in normal operation - but I wonder if it means something? I have a friend with a newer TC that does the same thing. Expand Mine did similar. When I turned the lights on to drive I saw the lights on fine, but with remote unlock at night I saw one light out. It was hard to tell and see with my old/cloudy headlights, but after further inspection when I was swapping out my bulbs for LEDs I found the marker light on the inside of the headlights (Beside the actual headlight bulb) was out. When looking at the light at nightI assumed it was the headlight bul. It was not. Swapped the bulbs and now no further issues. Quote Link to comment Share on other sites More sharing options...
mrtn Posted November 10, 2023 Share Posted November 10, 2023 Turn signal stalk in excited position? Quote Link to comment Share on other sites More sharing options...
