Christaynium Posted June 8, 2021 Share Posted June 8, 2021 I have 14 ftc passenger. I have removed the rear climate control hardware, but I'm trying to get my front ac to work. Is the electronics that were in the rear stoping me from having ac in the front, like an in car climate temp sensor? Quote Link to comment Share on other sites More sharing options...
G B L Posted June 9, 2021 Share Posted June 9, 2021 I suspect the module that control the ac is stopping you. If you removed the Rear evaporator then you will need to block it off and recharge the system. Quote Link to comment Share on other sites More sharing options...
Christaynium Posted June 13, 2021 Author Share Posted June 13, 2021 (edited) I blocked off the rear lines and recharged it. It worked for the night then the next day it worked at first but later that day it stoped working. I've now swapped in the OEM lines for Connects that don't come with rear climate control to eliminate chances for leaks. Unfortunately it doesn't work still. Since it worked at first after just blocking the lines, I guess I must have a failure else where. Edit: Actually I just needed to fill it more. Front Ac works without the rear hardware and modules plugged in. More storage and LiFePO4 space! Edited June 13, 2021 by Christaynium Quote Link to comment Share on other sites More sharing options...
