Dutcho Posted May 22, 2021 Share Posted May 22, 2021 Gents I'm trying to get a ford connect back up and running. It had a suspect pump problem so I've changed the pump and used forscan to program it to the van. The problem I'm having now is that even with a new battery the engine wont turn over its as if its locked. Starter seems fine out of vehicle and no locking pins are in place. It did turn over slowleybefore I started hence the new battery but now I get a healthy click like its stuck in gear?? Ideas welcome thanks for reading. Quote Link to comment Share on other sites More sharing options...
Dutcho Posted May 23, 2021 Author Share Posted May 23, 2021 I've tried turning the engine with a socket it seems I can get around 99 degrees movement either way but then it's as if the pump is hitting a hard stop? Any ideas thanks Quote Link to comment Share on other sites More sharing options...
G B L Posted May 24, 2021 Share Posted May 24, 2021 Did the engine turn over be for the pump was worked on ?Looks like you should take the pump out and see if the engine turns over freely. Have any pictures? Quote Link to comment Share on other sites More sharing options...
