DRL Daytime & Signal LED strips upgrade
I just installed directional LED strips on my 2014 TC front headlight assemblies ( before & after photos attached ) and the daytime lights now look as good as as the 2020 model! The same strip goes to a orange color with a directional DRL lighting show when the right or left signal is activated.. it looks sick! ? Just thought to share this quick and ease upgrade that cost about $25 from Amazon, if anyone is interested in more information about the sources or build steps. Cheers you'll
Edited by Vander Woestijn
6 hours ago, Vander Woestijn said:
strip goes to a red color with a directional DRL lighting show when the right or left signal is activated..
Laws are different everywhere.  Where I live, a forward facing red light, flashing or steady, is a violation of the motor vehicle code.  All forward facing lights must be white or yellow, with no more than 4 white lights illuminating the road.  In a lot of places, red lights are for police, fire, ambulance.......
  • 1 year later...
I am assuming you tapped into the headlight assembly wiring block, did you jump the "white" light off the low beam . parking light or other?
I got a set of these and haven't installed them as I wasn't sure if I want white "always on" with acc power or only when parking lamps are on.
