Ford Brand cross bars
Towerofjuju
Hey, we are new to the forum after recently buying a 2018 TC xl LWB. It came with the cross bars and I’m looking to adjust them. I have the key but can’t figure how’s to make the slide adjustment. I believe I need to remove the black end cap but don’t want to force/break them. Any suggestions?
Unlock, pull entire end cap out slightly, spin counterclockwise to loosen clamp, clockwise to tighten. Whole foot just slides back and forth to adjust once clamp is loose. The end cap is just a T-handle on the end of a long square shaft. You can even pull the whole shaft out once it's unlocked. The lock just keeps it from being pulled out and turned. Here some pix from the rails I removed from my 2015 when I upgraded to a 2020 without rails.
Edited by DonShockley
