bvz2000 Posted December 22, 2020 Share Posted December 22, 2020 I’ve looked around this forum and found a few mentions that this is possible, one even suggesting that there was a simple clip you could remove with the square pliers. But I can’t seem to get that to work. Can anyone tell me how to get this armrest off? Quote Link to comment Share on other sites More sharing options...
tnoll Posted July 4, 2021 Share Posted July 4, 2021 I needed mine off a 2019 cargo LWB. I have found the instructions ‘sit in passenger seat, raise arm to 60 degrees and pull out.’ My dealer and 5 mechanics couldn’t do it. They emailed ‘Ford engineers’ to double check and were told that was correct. Personally think the manual is out of date. I cut mine off because I was putting sheepskin covers on. Mine had a round rod inside the seat. Quote Link to comment Share on other sites More sharing options...
drum_buster Posted July 26, 2022 Share Posted July 26, 2022 OP Did you get this off? Were you fixing it, or would you sell it if you still have it? Quote Link to comment Share on other sites More sharing options...
tnoll Posted July 27, 2022 Share Posted July 27, 2022 (edited) Drum buster, not sure who you are addressing. I got it off a 2019, not by Ford instructions but had to cut the mount rod; dealer couldn’t get it off either. Didn’t care because I was putting sheepskin seat covers and an aftermarket console armrest from Armster dot com. Edited July 27, 2022 by tnoll addition Quote Link to comment Share on other sites More sharing options...
drum_buster Posted August 16, 2022 Share Posted August 16, 2022 Was addressing bvz2000. I was able to get mine off and repaired with some JB Weld. Put on a new press-nut lock washer but it still doesn't work quite correctly. (armrest wouldn't latch, would just fall down and block the e-brake and shift lever). It at lest doesn't fall all the way down. May look at aftermarket cup holder mount options. Mine is a 1st gen 2011, not 2019. Cheers Quote Link to comment Share on other sites More sharing options...
