2013 TC led turn signal bulbs
I have seen some on Amazon that have built-in load resistors, typically in the range of $40+ per pair. For my 2015, I ended up putting one 50W 6-ohm resistor on each rear turn signal and that cancelled the hyperflash even with my front signals also being LED. Since I also added a Curt trailer wiring hook-up, I cut & modified that instead of the vans OEM wiring.
