Connect Dayvan/camper insulation
Depends on your climate you're planning to protect for, but if you're going to camp in high temperature climates there's definitely a case to be made for minimal/lower R-value insulation over too much/higher R-value. Not to mention not wanting to encroach too much on the limited living space.
Basically, it's easier to warm up with a heater in a cooler climate than it is to cool down the inside air, but more importantly, all of the metal surfaces, which after a hot day which can hinder getting to sleep. I'm not really convinced that stuffing insulation in-between channels really does all that much due to the heat transfer from conduction of the various metal structures that typically extend beyond the stuffed areas.That said, I've found it important to, at the very least, cover what metal surfaces you can with carpeting, especially near the areas where you are sleeping (think radiating cold metal at night).
I went with a combination of 3M Thinsulate of varying thicknesses for different areas, cheap expanded foam I could cut up and use in some areas too that you'd get for quick flooring in the garage or whatever. I also used a reflectix equivalent when I could maintain an air gap or insulation barrier to help retain radiant heat from the propane heater.
Also came across a different insulation product that looked interesting after my build which looks easy to use with self-adhering properties that might be worth checking out if you can source it: http://www.armacell.us/products/aparmaflexsaaparmaflexfssa-duct/
Edited by connectvanplans
