Can’t pull the hood release because the passenger door won’t open when the battery’s dead
Just guessing you have right hand drive?
I went out and looked at my 2016 and when I tried to pull hood latch with the door closed,the latch handle would hit the plastic door panel before the hood would pop.
However,if i grabbed the handle on the side closest to the exterior,I could gently pull it diagonally enough to clear the plastic panel.
Some booster packs will charge your battery through your cigarette lighter.
https://mechanics.stackexchange.com/questions/15893/is-it-possible-to-charge-car-battery-through-cigar-lighter-socket
Edited by JackGrimshaw
