James Saddington Posted September 28, 2020 Share Posted September 28, 2020 Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
JackGrimshaw Posted September 29, 2020 Share Posted September 29, 2020 Door won't open or won't unlock? Quote Link to comment Share on other sites More sharing options...
JackGrimshaw Posted September 29, 2020 Share Posted September 29, 2020 (edited) Just guessing you have right hand drive? I went out and looked at my 2016 and when I tried to pull hood latch with the door closed,the latch handle would hit the plastic door panel before the hood would pop. However,if i grabbed the handle on the side closest to the exterior,I could gently pull it diagonally enough to clear the plastic panel. Some booster packs will charge your battery through your cigarette lighter. https://mechanics.stackexchange.com/questions/15893/is-it-possible-to-charge-car-battery-through-cigar-lighter-socket Edited September 29, 2020 by JackGrimshaw Quote Link to comment Share on other sites More sharing options...
