Connectrob1991 Posted April 1, 2020 Share Posted April 1, 2020 Please help I've got a 2006 royal mail transit connect 1.8 tddi with no engine light coming on at start up ran cluster test it lights up an plugged it in to obd reader comes up p1000 can't finish cummunication to ecu basically on cluster scan came up uo with dtc d262 under the understanding its something to do with pcm an cluster other forums advised check connections please help Quote Link to comment Share on other sites More sharing options...
mrtn Posted April 1, 2020 Share Posted April 1, 2020 does the led work? need repair sometimes. mine lost the clock. the guy repairing it said it’s a common problem with these clusters, connections break. Quote Link to comment Share on other sites More sharing options...
