Shorty76 Posted January 28, 2020 Share Posted January 28, 2020 Hi everyone I'm having a problem with van and looking for a bit of help . The van is starting different from normally and not as lively and eager to start also it's ultra sluggish like no turbo power even though I can here it while driving van drives just no power, no smoke 140000miles I had a drive shaft and inner cv done at garage last week and a fresh mot . Parked it up and next day noticed it was slow .it will rev right out in neutral though taking it much longer than usual I've had a quick look at hoses and can't see anything obvious except when you rev the van the left hand below (drivers side)on intercooler is bulging and the other one is not , has anyone else had this Thanks in advance Brian Quote Link to comment Share on other sites More sharing options...
G B L Posted January 30, 2020 Share Posted January 30, 2020 (edited) Living in US I do not have first hand experience of your TC Model. I will hazard a guess the hoses for the turbo to inter cooler were most likely moved for the Half shaft work if you have a bulging hose there is a restriction. Check there first keep us in the loop Edited January 30, 2020 by G B L Quote Link to comment Share on other sites More sharing options...
